#082 Working with Linear Bushings -5: Linear Bushing Application Example on Simplified Automation Equipment - 2
(2) Stepping Motors and Ball Screw Drive
-Ball screws provide good transmission efficiency and utilization of motor efficiency since [1] they directly convert motor's rotary motion into linear motion, and [2] the screw pitch works as a deceleration mechanism.
-[Fig.4] is a drive mechanism with ball bushings and a ball screw drive on the Y-axis, typically used where reduced cycle times and increased positioning accuracy are needed.
![[Fig.4] Ball Screw Driven Linear Bushing Mechanism [Fig.4] Ball Screw Driven Linear Bushing Mechanism](http://www.misumi-techcentral.com/tt/en/lca/images/082_1.gif)
(3) Air Cylinder Drive
-[Fig.5] is an air cylinder driven guide bearing of a clamp mechanism, and [Photo 2] is a magnetically coupled air cylinder mechanism. They both use linear bushings (arrow leader).
-Since the air cylinders cannot be velocity controlled during acceleration and deceleration, shock absorbers are used to reduce the shocks when stopping ([Photo 2]).
![[Fig.5] Air Cylinder Driven Clamp Mechanism, [Photo 2] Air Cylinder Driven Unit [Fig.5] Air Cylinder Driven Clamp Mechanism, [Photo 2] Air Cylinder Driven Unit](http://www.misumi-techcentral.com/tt/en/lca/images/082_3.gif)
(4) Vertical Guide Example
-For vertical guiding applications, use of flanged linear bushings can achieve compact and simple mechanism without dedicated retaining mechanisms provided. ( require a vertical base plate for guide rails)
![[Photo 3] Cover Open/Close Mechanism Example, [Photo 4] Table Height Fine Adjustment Mechanism [Photo 3] Cover Open/Close Mechanism Example, [Photo 4] Table Height Fine Adjustment Mechanism](http://www.misumi-techcentral.com/tt/en/lca/images/082_4.gif)
-Flanged linear bushings are also used for elevator mechanisms for transfer conveyors ([Fig.6]) and locating mechanisms ([Fig.7]), similar to the mechanism in [Photo 4].
![[Photo 6] Application Example for Conveyor Elevator, [Fig.7] Application Example for Locating Mechanism [Photo 6] Application Example for Conveyor Elevator, [Fig.7] Application Example for Locating Mechanism](http://www.misumi-techcentral.com/tt/en/lca/images/082_5.gif)
