HOME > Low Cost Automation Tutorial > #086 LCA in Transfer - Degree of Transfer Mechanization
Category : Hints on designing
August 5, 2011
In order to cope with various loads (weight, form factor: liquids and gases, micro components, etc.) different degrees of mechanization exist. The mechanization levels are classified and explained in the following table.
* Note 1)
Velocity control of linear transfers is commonly achieved by varying motor velocity, but LCA can be adopted for this by the use of non-linear gear combinations.
