HOME  > Plastic Molding Tutorial  > #013 : Thermal Expansion of Mold Components (Example of Calculation)
Category : Cavity
September25, 2009
Let us see a case study about the thermal expansion of mold components described in the last course.
Question:
The overall length of a core pin prepared in a 20°C machine formation room was 30.52 mm. When this core pin is heated to 150°C, how long is the amount of thermal expansion? The material of the core pin is pre-hardened steel of the SCM440 series.
Sample Answer:
The equation for calculating the thermal expansion of metals is the following. Let us substitute the values in this equation.
Where λ is the elongation (mm) of the core pin due to thermal expansion and α is the linear thermal expansion coefficient of the metal (mm/mm).
In the case of a pre-hardened steel of the SCM440 series, α = 11.5 x 10-6 mm/mm, l is the initial length of the core pin (mm), l= 30.52 mm, t is the initial temperature (°C), t = 20°C, and t is the temperature after heating (°C), t = 150°C.
Therefore, λ = 11.5 X 10-6 X 30.52 X (150-20) = 0.0456 (mm).
