HOME > Plastic Molding Tutorial > #135 Thermal Diffusion Coefficient of Major Plastics
Category : Cost
December21, 2012
In order to calculate the cooling time of plastic injection molded items, it is necessary to acquire the thermal diffusion coefficient of the plastic resin. Table 1 gives the thermal diffusion coefficients of some major plastic resins.
: The thermal diffusion coefficient of the plastic at the cavity surface temperature (mm2/sec) α=λ/(c・ρ) λ:Thermal conductivity of the plastic resin(kcal/m• h• °C) c:Specific heat of the plastic resin(kcal/kg• °C) ρ:Density of the plastic resin(kg/m3)
Table 1 Thermal diffusion coefficient of major plastic resins
※ | 参考文献:『射出成形金型』(三谷景造 (株)シグマ出版 (1997)) |
