#137 Nickel
Nickel can be used in materials of special metals or for electroplating on metal surfaces. Nickel is a silvery shiny metal.
The purpose of use of nickel in molds is mainly to exploit its resistance to corrosion. Nickel is extremely stable in air, and does not react to oxidation or retardation. It is also stable in water or brine and does not generate rust. In particular, it exhibits remarkable resistance to sulfuric acid and hydrochloric acid
In addition, nickel is also used in a condition in which it is alloyed with other metallic elements.
As a day-to-day application, the corrosion resistance of nickel is utilized in coins. In molds, nickel is used very often as films on the surfaces of molds in order to prevent gases or corrosive constituents being generated from molten plastics, cavity generation by adhered moisture, or to prevent corrosion of the core by oxidization.
In carbon steel, it is used as an alloy along with chromium (Cr), and is used widely as stainless steel for cavities, cores, and ejector pins, etc.
Since nickel is costlier than carbon steel, using it in the form of electroplated films or alloys can be said to be a rational method of use.
