HOME  > Surface Finishing Tutorial  > #098 Anodic oxide coatings on AL and AL alloys - 2
Category : Anodizing
October14, 2011
(4) Alkali corrosion resistance
Table 4 shows the allowable alkali corrosion ranges specified for the respective types of alumite film subjected to either the alkaline dropping corrosion resistance test or the electromotive force measurement test. (See the next section for the procedural details of the alkaline dropping corrosion resistance test and the electromotive force measurement test.)
[Table 4] Alkali corrosion resistance ranges (seconds)
Type Alkali dropping Electromotive force measurement
AA3 N/A
AA6 30 or more 90 or more
AA10 50 or more 150 or more
AA15 75 or more 225 or more
AA20 N/A/td> 300 or more
AA25 N/A 375 or more
(5) CASS corrosion resistance
Table 5 shows the CASS corrosion resistance ranges specified for the respective types of alumite films as subjected to the CASS corrosion test.
[Table 5] CASS corrosion resistance ranges
Type Test duration (h) Rating number
AA3 N/A
AA6 8 9 or more
AA10 16
AA15 32
AA20 56
AA25 72
(6) Wear resistance
Table 6 shows the wear and abrasion resistance ranges for the respective types of alumite films as subjected to the sand-falling abrasion resistance test, the abrasive jet test, or the reciprocating wear test. (See
[Table 6] Wear resistance
Type Sand-falling abrasion
resistance test
(s)
Abrasive jet
test (s)
Reciprocating wear test
(DS/μm)
AA3 N/A
AA6 150 or more N/A Number of times of reciprocating motion required to wear 1 μm of alumite film
AA10 500 or more 24 or more
AA15 750 or more 36 or more
AA20 1,000 or more 48 or more
AA25 1,250 or more 60 or more
(7) Stain resistance
Table 7 shows the stain resistance range specified for all types of alumite films as subjected to the chromic-phosphoric solution immersion test, the dye spot test, or the admittance test:
[Table 7] Stain resistance
Type Chromic-phosphoric solution
immersion test (g/dm2)
Dye spot test
(degree of staining (grade))
Admittance test (μS*)
(Microsemens per film thickness of 20 μm)
AA3 to AA25 0.03 or less 0 to 2 20 or less
(8) Designation convention for alumite films
The designation of an alumite consists of a prefix for type, followed by letters for corrosion resistance, wear resistance, and stain resistance in this order:
Alkaline dropping corrosion resistance test = KS; electromotive force measurement test = KG; CASS corrosion test = L; sand-falling abrasion resistance test = WF; abrasive jet test = WJ; dye spot test = SD; chromic-phosphoric solution immersion test = SP
Example 1: AA15/L-WJ: 15 μm-thick film, having passed the CASS corrosion test and the abrasive jet test
Example 2: AA6/KS-WF: 6 μm-thick film, having passed the alkaline dropping corrosion resistance test and the sand-falling abrasion resistance test
