#203 Lubricating Paints
Lubricating paints are used in areas where it is difficult to lubricate with oil/grease commonly used, in areas that are not compatible with greasing by such agents, and in rolling bearings used under a special atmosphere such as in a vacuum. They are also used to reduce friction between sliding objects and/or to improve resistance to abrasion and corrosion. With the developments in the sectors of precision industry and semiconductor manufacturing in recent years, dust- and maintenance-free features are required, and thus the self-lubricating properties achieved by these lubricant is increasingly demanded.
Types of lubricating paints include molybdenum disulfide lubricating paints, tetrafluoroethylene lubricating paints, graphite lubricating paints, and boron nitride/tungsten disulfide lubricating paints.
(1) Molybdenum disulfide lubricating paints
This type of paint is used for the following:
1. | Friction area of a machine where micro-vibrations are likely to occur | |
2. | Plastic forming such as wire drawings/cold extrusion of stainless steel, titanium, aluminum, etc. | |
3. | Lubrication of rolling bearings, sliding bearings, and screws used in a special atmosphere such as in a vacuum or under high/low temperature environments | |
4. | Antirust and lubrication of springs used for railroad vehicles and automobiles | |
5. | Lubrication of cameras, office machines and other machines |
and other purposes.
(2) Tetrafluoroethylene resin lubricating paints
This type of paint is used for a wide range of applications from bridges, dams, and floodgates operated under low-speed / high-load conditions to kitchen instruments such as frying pans.
For example, it is used for the following:
1. | Fulcrum of bridges and bearings of floodgates that are used under high-load / low-speed conditions | |
2. | Bearing alloys and glass foundation cloth, etc. (used as lubricants by impregnating them with this paint) | |
3. | Improving sliding performance of clocks, sewing machines, and irons, etc. | |
4. | Adding non-viscous properties to the instruments for food, fibers, paper manufacturing, and kitchen | |
5. | Lubrication of general machinery | |
and other purposes.
(3) Graphite lubricating paints
This type of paints is used in an atmosphere where it is not possible to use molybdenum disulfide or tetrafluoroethylene resin.
1. | Lubrication of sliding components used in a high-temperature atmosphere such as boiler's heat exchanger or casting equipment, as well as ones used in an environment where there is the effects of radiation such as a nuclear reactor | |
2. | Lubrication during hot working processes of metals such as casting, drawing, or extrusion, as well as mold releasing during hot working processes of glass |
and other purposes.
(4) Boron nitride/tungsten disulfide lubricating paints
This type of paint has the following uses:
1. | High-temperature mold release agent | |
2. | Lubricants for breaking in a machinery |
and other uses.
