HOME > Surface Finishing Tutorial > #226 JIS (Japanese Industrial Standards) for Plating
February12, 2016
Let's take a look how the JIS defines each type of plating (such as chrome plating and zinc plating).
The JIS defines the types, grades, and symbols for electro-galvanizing as shown in the table below.
(1)Plating name
1. 8 µm electro-galvanizing on steel substrate, bright chromate-treated
EP-Fe/Zn 8/CM1 or EP-Fe/Zn[3-C1]
2. 13 µm electro-galvanizing on steel substrate, colored chromate-treated
EP-Fe/Zn 13/CM2 or EP-Fe/Zn[4-C2]
(2)Corrosion resistance of chromate films
To meet the required level of corrosion resistance, chromate films of Grade 2 to Grade 6 in Plating Type 2 should have no visible white product generated on the surface within 48 hours of a neutral salt spray test. In this case, Type 1 AB and Type 2 Grade 1 are excluded as test subjects.
