HOME > Surface Finishing Tutorial > #254 Combination of Multi-layered Decorative Plating by Application
August26, 2016
To improve the appearance and product value, decorative plating will be applied on top of the layers consisting of the bottom layer (base plate) spread over mechanically conditioned substrate and the medium layer applied for enhanced corrosion resistance. The following combinations are common for each application:
* | Satin nickel and Velours® nickel are the plating process product names. Both have semi-bright satin finish. |
