#262 Gold and Gold Alloy Plating for Engineering Purposes
This section of JIS defines gold and gold alloy plating with the thickness of at least 0.2 µm on a metal or nonmetal substrate, produced for engineering purposes, including electrical / electronic products, machinery and other functional components.
(1) Definition of terms
1. Gold plating
Soft gold plating refers to electroplating with its gold content being 99.9% or more.
2. Gold alloy plating
This refers to electroplating with its gold content being 58.8% or more but no more than 99.9%. This plating is harder compared to the gold plating described earlier.
3. Multi-layer gold or gold alloy plating
This refers to plating comprised of two or more layers with different gold content.
(2) Quality
Here are the assessment items for determining the quality of plating films.
1. Appearance
Check the quality of polish, radiance and color, along with imperfections as roughness, burnt parts or pits.
2. Plating thickness
The minimum plating thickness is classified as follows:
[Table] Classification by the minimum plating thickness
3. Gold content in plating
4. Porosity of plating
Nitric acid aeration test (explained in another volume)
5. Resistance to discoloration by heating
Applicable to thick plating (explained in another volume)
6. Corrosion resistance of plating (explained in another volume)
7. Plating adhesion
8. Solder wettability of plating
9. Residual salt on significant plating surfaces
10. Electrical properties of plating
11. Plating hardness
12. Abrasion resistance of plating
(3) Plating name
Plating names are described by the symbols shown in this table.
In the next volume, we will learn testing methods of nitric acid aeration test, color fastness test by heating, and hydrogen sulfide test for industrial gold and gold alloy plating.
