#088 Natural Colorization of Anodizing
The color of anodize coatings vary depending on the electrolytic process conditions such as aluminum alloy type, electrolyte bath, and power supply waveform. The [Table 1] and [Table 2] show electrolytic colorization under a DC power supply, and these colors will vary further by the coating thickness. Thicker coatings will have darker colors.
[Table 1] Natural Colorization of Anodize Coatings (Rolled material)
[Table 2] Natural Colorization of Anodize Coatings (Cast / Die-cast)
Therefore, the following must be considered when designing products with anodizing.
1. When selecting an aluminum alloy material, confirm that a desired color can be obtained by anodizing process.
2. When useable aluminum alloy is limited due to manufacturing method and strength for usage, and such alloy has its distinctive anodized color, use dying or electrolytic coloring to obtain the desired color.
3. When dark colorization is unavoidable due to specific condition such as applying a hard anodizing on some specific alloys, have the clients understand that the colors cannot be changed in order to preserve the wear resistant property of the coating.
