#287 The degree of difficulty of plating of copper and copper alloys
April14, 2017
Type | Characteristics | Typical applications | Degree
of
difficulty |
Dilute copper based alloys | Including little alloy elements | High-performance springs, electrical machinery and appliances, and engine parts Chemical industrial equipment and electrical machinery | ◎ |
| Oxygen-free copper | Excellent in electric conductivity, thermal conductivity, malleability, and drawing workability, and satisfactory in weldability, corrosion resistance, and weather resistance. |
Tough pitch copper |
Phosphorous-deoxidized
copper | Satisfactory in malleability, drawing workability, weldability, corrosion resistance, weather resistance, and heat conduction. | Water heaters, gaskets, and building materials | ◎ |
Beryllium copper | Satisfactory in corrosion resistance, offering reinforced fatigue resistance by precipitation hardening treatment. | High-performance springs, switches, and connectors | ○ |
Copper-zinc alloys | Glossy and satisfactory in malleability, drawing workability, and corrosion resistance. | Building materials, personal ornaments, cosmetic cases, and waveguides | ◎ |
| Red brass |
Brass | Wiring accessories, nameplates, and electro-mechanical parts | ◎ |
Copper-zinc-lead alloys | Containing some amount of lead and zinc and excellent in machinability. | Clocks, gears, papermaking screens, bolts, nuts, valves, and spins | ○ |
| Free-cutting brass |
Copper-zinc-tin alloys | Satisfactory in corrosion resistance, excellent in corrosion resistance in sea water in particular. | Heat exchanger tube plates and sea water intake facilities in vessels | ○ |
| Naval brass |
Copper-tin-phosphor alloys | Satisfactory in malleability, fatigue resistance, and corrosion resistance, and suitable as materials for high-performance springs. | Switches, connectors, relays, and cams | ○ |
| Phosphor bronze |
Copper-nickel-zinc alloys | Glossy, and satisfactory in malleability, fatigue resistance, and corrosion resistance.
Suitable as materials for high-performance springs. | Switches, relays, connectors, medical equipment, musical instruments, and eyeglass frames | ○ |
| Nickel silver |
Others | ○ |
| Aluminum bronze, brass for musical instruments, high strength brass, IClead framesCu-Sn, Cu-Fe,etc. |
* | ◎:Satisfactory adhesion is attained.○:Adequate consideration must be given to pretreatment. |
Copper and copper alloys are available in the form of wrought products and castings.
For wrought products, the materials in the form of sheet, wire, rod, or pipe will be punched, drawn, bent, or machined to the intended shape for finished products and then subject to plating.
A critical point in the plating is making the materials and the item's processing history clear.
