HOME > Surface Finishing Tutorial > #150 Coating Characteristics of Functional Plating (Industrial plating)
February15, 2013
Characteristics of functional platings (Industrial platings) are as follows.
■Explanation of the characteristics
| 1. | Build-up: Thick plate coatings that can compensate for inadequate dimensions. | |
| 2. | High frequency characteristics: Conducts high frequency AC well. Good high-frequency current wave guiding properties. | |
| 3. | De-molding characteristics: Easy to extract products from diecast and resin molds. | |
| 4. | Non-adhesiveness: A characteristic that makes things not sticky. Promotes de-molding characteristics. | |
| 5. | Lubricity: Slipperiness. Use of lubricants reduces friction and prevents wear. | |
| 6. | Low contact resistance: Small contact resistance at electrical connections. | |
| 7. | Porosity: A characteristic that possesses many minute pores on the plate coating surfaces. It is said to be "Porous". | |
| 8. | Printing durability: Characteristics that retains ink and dye on printing plates well, and able to print evenly. | |
| 9. | Adhesiveness: A characteristic that improves adhesion power of the plate coatings and polymer substances (rubber, plastics, etc.). | |
| 10. | Realism repeating ability: A characteristic that can copy signals of CD stamper, and etc. with high fidelity. | |
| 11. | Electro conductivity: Conducts electricity well due to low electrical resistance. It can shield electromagnetic waves. |
