#202 Antistatic Paints
Disasters and accidents related to static electricity are caused by electrostatic attraction or discharge. Examples of accidents related to electrostatic discharge include: [1] Fire ignited by flammable materials; [2] Electric shock/discomfort to human body; [3] Light exposure to photographic films, etc.; [4] Failure or destruction of electronic devices including IC; [5] Malfunction or fire in chemical equipment, etc. Unfavorable events by electrostatic attraction include: [1] Attachment of dust, bacteria, or mold onto electronic devices/components and precision machinery components; [2] Clogging of pipes of precision machinery; [3] Irregularity (jamming) of sheets/films, etc.; [4] Entanglement of threads/fibers; [6] Printing failure; [6] Discomfort to human body.
In Japan, these accidents used to occur in the winter time when humidity is low. However, due to the spread of air-conditioning use and the development of precision electronic components, it is now necessary to implement the countermeasures all year round. The areas that require countermeasures against static electricity include indoor locations, floors, electronic devices and components. [Table 1] shows electrical (leakage) resistance based on the hazard and obstacle levels of the work environment.
[Table 1] Work environment and electrical resistance on floor surface
The following materials are used for the antistatic coatings.
The combination of carbon conductive paints and coated materials includes the followings: [1] Acrylic coating with ABS resin, PS, or PPO coated materials; [2] Urethane coating with FRP or polyester; [3] Polyolefin coating with PP or FRP; [4] Alkyd coating with metal; [5] Epoxy resin coating with metal, FRP, or cement.
Carbon powders are stable in the heat. Most of them are made with melamine-based materials with room temperature setting or thermosetting properties.
For the clean room specification, acrylic or vinyl materials are used for walls, ceilings, and light-duty floors while urethane or solventless epoxy materials are used for heavy-duty floors.
In addition, highly conductive carbon coatings are applied to plastic cases of electronic equipment as a static protection measure.
