#261 Bond Test Methods for Plating
(1)Description of the bond test methods
The test methods introduced here are available for measuring the adhesiveness of electroplating. Select an appropriate method according to the characteristics of plating films.
1)Cathode electrolysis test
Measure the adhesiveness of nickel/chrome plating on a steel substrate through electrolysis.
2)Push-out test
Create a hole (not a through-hole) from the back side of a plated surface. Use a stick to push it out. This method is for industrial chromium.
3)Ruled line test
Use a needle-like tool to scratch a sample surface. This test is appropriate for soft plating.
4)Grinding test (1.Grinding stone. 2. File)
Test the adhesion by grinding the plated surface using 1 and 2.
5)Chisel test
Insert a sharp chisel between the plated layer and substrate to measure the adhesiveness.
6)Thermal test (1. Heating test, 2. Thermal-shock test)
(To be described later.)
7)Barrel polishing test
Rotate the barrel with a steel ball and a plating sample in it. This method is not compatible with soft plating.
8)Peeling test (1. Tape test, 2. Solder test)
9)Tensile test
Apply a tensile stress to the sample until it fractures. Measure the adhesiveness by the degree of extensibility.
10)Bend test
11)Winding bend test
Wind a thin wire or a strip around the mandrel. (Mandrel test)
(2)Tape test
In this method, you will measure the adhesiveness by pasting an adhesive tape on a plated surface and peeling it off as quickly and hard as you can. It is suitable for relatively thin plating. This method is not appropriate for thick plating. You need to use tapes with the width of 12 to 19 mm defined in JIS Z 1522.
Before pasting a tape, leave a streak mark that reaches through the substrate as you draw a 2-mm square using a sharp knife to make the assessment more accurate.
(3)Bend test
This test measures the plating adhesiveness by bending a test sample. Use stakes with the bending radius of between 4 and 10 mm to secure the sample onto a vise. Repeat the process of bending the sample on the vise by 90 degrees back and forth. This method is not compatible if the plating thickness exceeds 2 mm.
(4)Thermal-shock test
This test measures the adhesiveness by a heat shock when the heated sample is rapidly cooled down. Heat up the sample in the furnace until it reaches to the temperature shown in [Table 1]. Then, remove the sample and quench it in room-temperature water.
[Table 1] Furnace and test temperature
