#318 Chromate Films on Zinc Plating
November17, 2017
The chromate treatment over zinc plating is designed to add gloss finish or color tones, such as pale yellow, yellow, and green, while drastically enhancing the corrosion resistance by forming anti-corrosive films over the zinc-plated surfaces.
(1) Grades, types, and symbols of chromate films
[Table 1] Grades, types, and symbols of chromate films
| Grade |
Type |
Symbols for grades & types |
Film mass per unit area (g/m2) Note) |
Common shades of color |
| Grade 1 |
Gloss |
CM1 A |
0.5 or less |
Transparent, or a tinge of blue at times |
| Pale yellow |
CM1 B |
1.0 or less |
Slight interference pattern |
| Grade 2 |
Yellow |
CM2 C |
More than 0.5 but not greater than 1.5 |
Yellow interference pattern |
| Green |
CM2 D |
Greater than 1.5 |
Olive, green, bronze, brown, etc. |
Using a different type of solution will generate black chromate films. The film mass per unit area for the black chromate films should be determined and agreed between the parties concerned. |
(2) Mass measurement method for chromate films
For the measurement, it is necessary to prepare a test piece consisting of the surface area shown in [Table 2] (24 hours but no more than 14 days elapsed from the chromate treatment), and the one-liter solution that is made by dissolving 50 g of sodium cyanide and 5 g of sodium hydroxide into pure water. The mass is measured by a reduction of weight after soaking the test piece into this solution for one minute, while cathode current density stays at 15 A/dm2 to dissolve the chromate film.
[Table 2] Total surface area of test pieces
| Estimated film mass per unit area (g/m2) |
Minimum total surface area (cm2) of test pieces |
| Less than 1 |
400 |
| 1 or more and less than 10 |
200 |
| 10 or more and less than 25 |
100 |
| 25 or more and less than 50 |
50 |
| 50 or more |
25 |
(3) Corrosion resistance of chromate films
The minimum hours shown in [Table 3] must be satisfied after conducting a neutral salt spray test consecutively.
[Table 3] Corrosion resistance of chromate films
Minimum hours (h) without generating white corrosion product |
| CM1 A |
6 |
| CM1 B |
24 |
| CM2 C |
72 |
| CM2 D |
96 |
(4) Notation of chromate films
Ep-Fe/Zn 25/CM2 D
Electro-galvanizing deposited at 25 µm or higher on a steel substrate, topped with Grade 2 green chromate film
Ep-Fe/Zn 8/CM1A
Electro-galvanizing deposited at 8 µm or higher on a steel substrate, topped with Grade 1 gloss chromate film
Reference This standard applies to chromate films on electroplated coatings of cadmium as well. In recent years, chromate films containing hexavalent chromium have been linked to environmental problems. As a result, chromate films free from hexavalent chromium were developed. This new alternative will become the mainstream in the future. |
