HOME > Low Cost Automation Tutorial > #150 Production Technology Improvement Course for Mechanical Designers - 20: Component Alignment Technology: Alignment Method Examples
March 1, 2013
In the Vol. 153, an example of direction changes on a linear feed hopper was explained. In the Vol. 154, direction changes on a vibratory bowel feeder will be explained using an example.
Example 1: Direction changes of screws
| - | Screws are stored in a vibratory bowel feeder. |
| - | Screws rotate counterclockwise receiving minute vibrations by a vibrating body beneath the bowel. |
| - | Based on the screw orientation at the alignment location (A), the screws are sorted in only one direction by theGate Shape* (Explained in details in Vol.155 & 156), and fed through to be aligned. |
| - | The vibrations will feed the aligned screws forward. |
