HOME > Surface Finishing Tutorial > #312 Grades and Symbols of Nickel and Chrome Plating on Zinc Alloy Substrates
October 6, 2017
This standard defines the types of plating applied on zinc alloy die casting for decorative and anti-corrosion purposes, as well as the plating thickness of the significant surfaces and the corrosion-resistance properties. (The corrosion resistance properties are described in another section.)
[Table] Nickel and chrome plating on zinc alloy substrates
| Grade | Base-coat plating | Base-coat plating Minimum thickness (µm) |
Top-coat plating | Top-coat plating Minimum thickness (µm) |
Symbol
| Grade 1 | Cu, Nib | 10 | Cr r | 0.1 | EP-Zn/Cu+Nib 10, Cr 0.1 r or EP-Zn/Cu+Nib, Cr r [1] |
| Grade 2 | Cu, Nib | 15 | Cr r | 0.1 | EP-Zn/Cu+Nib 15, Cr 0.1 r or EP-Zn/Cu+Nib、 Cr r [2] |
| Grade 3 | Cu, Nib | 20 | Cr r | 0.1 | EP-Zn/Cu+Nib 20, Cr 0.1 r or EP-Zn/Cu+Nib, Cr r [3] |
| Grade 4 | Cu, Nib | 25 | Cr r | 0.1 | EP-Zn/Cu+Nib 25, Cr 0.1 r or EP-Zn/Cu+Nib, Cr r [4] |
| Grade 5 | Cu, Nib | 30 | Cr r | 0.1 | EP-Zn/Cu+Nib 30, Cr 0.1 r or EP-Zn/Cu+Nib, Cr r [5] |
| Grade 6 | Cu, Nib | 40 | Cr r | 0.1 | EP-Zn/Cu+Nib 40, Cr 0.1 r or EP-Zn/Cu+Nib, Cr r [6] |
| Grade 7 | Cu, Nib | 40 | Cr mc | 0.1 | EP-Zn/Cu+Nib 40, Cr 0.1 mc or EP-Zn/Cu+Nib, Cr mc [7] |
| Cu, Nib | 40 | Cr mp | 0.1 | EP-Zn/Cu+Nib 40, Cr 0.1 mp or EP-Zn/Cu+Nib, Cr mp [7] |
| Grade 8 | Cu, Nib | 50 | Cr r | 0.1 | EP-Zn/Cu+Nib 50, Cr 0.1 r or EP-Zn/Cu+Nib, Cr r [8] |
| Cu, Nid | 30 | Cr mc | 0.1 | EP-Zn/Cu+Nid 30, Cr 0.1 mc or EP-Zn/Cu+Nid, Cr mc [8] |
| Cu, Nid | 30 | Cr mp | 0.1 | EP-Zn/Cu+Nid 30, Cr 0.1 mp or EP-Zn/Cu+Nid, Cr mp [8] |
| Grade 9 | Cu, Nid | 50 | Cr r | 0.1 | EP-Zn/Cu+Nid 50, Cr 0.1 r or EP-Zn/Cu+Nid, Cr r [9] |
| Cu, Nid | 40 | Cr mc | 0.1 | EP-Zn/Cu+Nid 40, Cr 0.1 mc or EP-Zn/Cu+Nid, Cr mc [9] |
| Cu, Nid | 40 | Cr mp | 0.1 | EP-Zn/Cu+Nid 40, Cr 0.1 mp or EP-Zn/Cu+Nid, Cr mp [9] |
* The plating thickness of multilayer plating comprised of Cu/Nib or Cu/Nid will be determined and agreed between the parties concerned.
