HOME > Surface Finishing Tutorial > #311 Grades of Nickel and Chrome Plating on Copper and Copper Alloy Substrates
September29, 2017
This standard defines the types of plating applied on copper and copper alloy substrates for decorative and anti-corrosion purposes, as well as the plating thickness of the significant surfaces and the corrosion-resistance properties.(The corrosion resistance properties are described in another section.)
[Table] Nickel and chrome plating on copper and copper alloy substrates
| * | The plating thickness of duplex nickel plating will be determined and agreed between the parties concerned. |
Cr mc: Microgram of microcracked chromium plating surface
This is a type of chrome plating containing evenly distributed micro-cracks, which are designed to distribute corrosion current and improve the anti-corrosion properties. This type of deposit can be formed by applying chromium plating over a special type of nickel plating on a nickel-plated substrate, or the same cracks can be generated over a thick layer of chromium plating. |
Cr mp: Microgram of microporous chromium plating surface
This is a type of chrome plating containing evenly distributed tiny pores in its surface. The pores are designed to distribute corrosion current and improve the anti-corrosion properties. This type of deposit can be formed by applying chromium plating over nickel coating containing non-conductive fine particles, or by directly applying chromium coating containing non-conductive fine particles. |
