HOME  > Surface Finishing Tutorial  > #314 Corrosion Resistance of Nickel/Chrome Plating
October20, 2017
The JIS grades of corrosion resistance for plating must be at least Grade 9 after the hours of each testing specified in Table.
[Table] Corrosion resistance of nickel and chrome plating
Unit: Hour
Basis metal Plating type Grade Neutral salt spray test CASS test Ferroxyle test Operating environment
Note 2)
Steel Copper/Nickel plating Grade 1, 2 - - ○
Note 1)
D
Grade 3, 4, 5 24 - - D
Copper and Copper alloy Nickel plating Grade 1, 2, 3 24 - - D
Steel Nickel/Chrome plating and Copper/Nickel/Chrome plating Grade 1, 2, 3 - 4 - D
Grade 4, 5 - 8 - C
Grade 6, 7, 8 - 16 - B
Grade 9 - 24 - A
Copper and Copper alloy Nickel/Chrome plating Grade 1 - 4 - D
Grade 1, 2 - 8 - C
Grade 3, 4 - 16 - B
Grade 5 - 24 - A
Zinc alloy Copper/Nickel/Chrome plating Grade 1, 2 - 4 - D
Grade 3, 4 - 8 - C
Grade 5, 6, 7, 8 - 16 - B
Grade 9 - 24 - A
Aluminum and Aluminum alloys Nickel/Chrome plating Grade 1 - 4 - D
Grade 2 - 8 - C
Grade 3 - 16 - B
Grade 4 - 24 - A
* Note 1) Ferroxyle test
This testing is designed for checking the corrosion resistance of copper/nickel plating or nickel/chrome plating applied over steel substrates. In this test, paste a filter paper soaked with ferroxyl test solution over the significant surface and peel it after five minutes. The anti-corrosion properties can be measured by the blue spots indicating the presence of iron complex, which appear on the paper.
* Note 2) Operating environment
A: Highly corrosive outdoor environment, such as coastal areas and industrial zones
B: Normal outdoor environment, such as rural zones and residential areas
C: Highly humid indoor environment, such as bathrooms and kitchens
D: Normal indoor environment, such as inside of houses and offices
