#315 Electroplated Coatings of Gold and Gold Alloy for Decorative Purposes
JIS defines the significant surfaces of gold and gold alloy plating for decorative purposes, which are applied over watches, personal ornaments and miscellaneous goods, as described hereinafter.
(1) Term definition
1. Gold plating
Electroplated coating consisting of the gold content of 99.9% or more and generally classified in the soft plating category.
2. Gold alloy plating
Plating consisting of the gold content of at least 58.5% but less than 99.9% and usually harder than gold plating.
3. Multilayer plating
Two or more layers of coatings that are plated by materials in varying gold content.
(2) Appearance
The requirements of silver plating for engineering purposes also apply to the appearance of gold plating. The appearance is especially important for this type of plating.
(3) Plating thickness
[Table] shows the classifications by the minimum plating thickness.
[Table] Classification by the minimum plating thickness
(4) Gold content
If the gold content is specified at a particular value (layer-specific values for multilayer plating), the content will be measured by a chemical method that is defined separately.The specified value must be satisfied.
(5) Porosity of plating
If the porosity is specified, it must be verified by a nitric acid aeration test.
(6) Corrosion resistance of plating
If the corrosion resistance is specified, it must be evaluated by a neutral salt spray test or a CASS test.
(7) Plating adhesion
The plating adhesion can be verified by test methods including a tape test and a thermal-shock test.
(8) Others
In addition to the conditions mentioned here, the following characteristics may be required:
1. Plating thickness, 2. Abrasion resistance of plating, 3. Conditions of the substrate, 4. Type and thickness of base-coat plating, etc.
(9) Plating name and symbol
●Ep-Cu/Nib, D-Au5
Decorative gold plating with a thickness of at least 5 µm over bright nickel base-coat plating on a brass substrate
●Ep-Zn/Cu10, Ni5b, D-Au0.5/PA
Zinc die casting alloy substrate, 10 µm-thick copper base-coat plating, 5 µm-thick bright nickel base-coat plating, and decorative gold plating of at least 0.5 µm thickness over it, with transparent urethane finish
●Ep-Fe/Nib, D-Au (60.0) 10, D-Au(90.0) 3
Two-layer plating consisting of decorative gold alloy plating (gold content of 60%) with a thickness of at least 10 µm and decorative gold alloy plating (gold content of 90%) with a thickness of at least 3 µm over bright nickel base-coat plating on a steel substrate
