#067 Troubles and Countermeasures for Air Cylinder Selections
In this discussion, pneumatic system component selection troubles and countermeasures are explained based on an example of "Unstable Actuation Time".
Following causes are conceivable for unstable air cylinder actuation time.
| 1. | Supplied air pressure and volume | |
| 2. | Increase of cylinder internal resistances | |
| 3. | Load rate on air cylinders | |
| 4. | Cushion function of air cylinders | |
| 5. | External resistances and structural influences |
The item 3. and 4. are explained here
(3) Problems caused by air cylinder load rates and countermeasures
The Load Rate is a rate of cylinder force capacity vs. applied load (W), and represented by the following formula.
When assimilating the instability of air cylinder actuation time with performance instability of automobiles, the cylinder force would be analogous to engine horsepower, and applied cylinder load to automobile weight. It can be understood that an automobile (air cylinder) must have appropriate power to weight ratio. The key point on LCA designing is to reduce (enlighten) applied loads.
Countermeasures for Load Ratio Related Problems
| ・ | Use air cylinders at as high a pressure as possible | |
| ・ | Select the largest cylinder bore diameter |
(4) Countermeasures for Cushion Function Related Problems
There are air cylinders with and without cushions. In cases when a) applied loads are high, and/or b) operation speeds are high, the cushion function can degrade due to repeated usage and cylinder operation can become unstable.
(a) When the applied load is high
Kinetic energy can be obtained by the following formula. When E exceeds the air cushion capacity (shock absorber's max. energy absorbing capacity), a cylinder with one rank higher bore diameter should be selected.
(b) When the velocity is high
Same principle as the case of high loads. Select a cylinder with one rank higher bore diameter.
Countermeasure for Cushion Related Problems
| ・ | Select a cylinder with one rank higher bore diameter for both High Load and High Speed cases. |
