HOME > Low Cost Automation Tutorial > #136 Mastering Ball Screws - 6 : Life of Ball Screws
November 9, 2012
Since the ball screws are designed based on rolling steel ball bearings, product service life calculations are backed by a solid theoretical system.
(1) Life of rolling ball bearings
| - | Here, we consider the ball screw life based on them as being analogous to the general purpose ball bearings. There are following 5 items as representative functionalities of ball bearings. (1) Little friction (2) Smooth rotation and quiet (3) Good accuracies (4) High load bearing capability (5) High rigidity | ||
| - | The life (in a broad sense) can be defined as an ability to retain these functionalities (durability). | ||
| - | Various defects, damages, and deterioration (accuracy degradation, noise increase, torque increase, and wear, etc.) are what degrade the ability to retain the functionalities. | ||
| - | Noise and torque increses are often attributed to ball screw systems designs, handling, and installation accuracies. | ||
| - | However, the Flaking caused by rolling fatigue can occur even with proper designing and installing, and the JIS defines this as Life in a narrow sense.
(2) Life of a typical ball screw (Life in a narrow sense)
Other than ball screws with high preloads, the typical ball screw life can be approximately determined by the following calculation formula (07 MISUMI Catalog, P2532)
