HOME > Surface Finishing Tutorial > #220 Methods of Thickness Test for Plate Coating
November27, 2015
When you place or receive an order of plate coating work, the thickness of the plating film is probably the most important specifications. The plating type and thickness are determined by the operating environment and purposes of the particular product. This section explains how to measure the thickness of plate coatings.
(1) Methods of the thickness test
JIS provides the following methods to test the thickness of plate coatings:
(2) Sampling method
| 1. | In general, collect a sample from the significant surface of the plated goods. If it is not possible, substitute the significant surface of the plated goods with a test piece made of the same materials and created in the same conditions as the subject goods. | |
| 2. | The sample surface must be clean. If any dust or oil content was found on the surface, remove them without damaging the plated surface before performing the test. |
