#007 : Selecting shaft holders
L shaped shaft holders are available in four shaft mounting configurations. Characteristics for the four types are organized below as selection references.
The holders in [Fig.1 Side insertion type] and [Fig.3 Separate type] have similar appearances with a difference only in shaft mounting methods. It can be seen from the figures that the shafts are inserted/removed in different manners. The difference affects the moving table assembly procedure and maintenance work. Chart below compares the differences of the four types.
![[Fig.1][Fig.2]](http://www.misumi-techcentral.com/tt/en//lca/images/007_1.gif)
![[Fig.3]](http://www.misumi-techcentral.com/tt/en//lca/images/007_2.jpg)
Other than the types shown in the table above, there are four other shaft holders such as T-type, bottom mount type, and side mount type. These can also be selected based on the perspective shown below.
Perspective for shaft holder selection
| 1. | Assembly/maintainability | |
| 2. | Placement relationship with surrounding components | |
| 3. | Degree of mounted part strength | |
| 4. | Ease of standardization |
