HOME > Low Cost Automation Tutorial > #092 Motion mechanism design - 37: Clamping devices for motor shafts and sprockets
September30, 2011
| Methods of fastening two coaxial rotating parts (shaft and hub pair: shaft and sprocket, gear, pulley, etc.) include: (1) keyed fastener, (2) screw fastener, and (3) friction locking methods. This section describes an easy-to-lock-and-unlock, reliable friction locking device, the standard Mecha-lock (FACE FA Standard Parts Catalog P993−996: [Photo 1]) |
(1) Principle of friction locking
The screws of a friction locking device tighten to apply radial force to the outside diameter surface of a shaft and the inside diameter surface of a hub to produce the frictional force that coaxially locks the shaft and the hub.
(2) Structure of Mecha-lock
The Mecha-lock selected for use in the work transfer conveyor is a tapered sleeved MLNP10. (See p. 996 of the catalog and Fig. 1.)
| Tightening the locknuts produced the nominal force by the wedge effects from the outer ring and the inner ring. The frictional force produced by the nominal force locks the motor shaft and the sprocket. |
