HOME  > Low Cost Automation Tutorial  > #282 Spring Design -10: Materials for Springs
March31, 2017
Spring characteristics are added by their materials, the heat treatment process, and forming methods (hot/cold forming).
(1)Hot forming and cold forming
=Hot forming
A forming method involving quenching and tempering in order to add necessary strength for the springs after they are formed into shape.
=Cold forming
A forming method involving quenching, tempering, or wire extension for the materials to which necessary strength is already added.
(2)Material for springs
The following table summarizes typical spring materials and application.
[Fig.1] Typical metal materials for springs
Symbol Name Application Major application Method
For general use Conductivity Heat resistance Corrosion resistance Fatigue resist
SW-B Hard steel wire ○ - - - - Small coils for
general machinery
Springs
SWP Piano wire ○ - - - ○ Same as above Same as above
SWO Carbon steel oil-tempered
wire for springs
○ - - - - Medium to large coil
springs for general
machinery
Same as above
SWOSC Oil-tempered
chromium
silicon alloy steel wires
for springs
- - ○ - ○ Same as above Same as above
SUS-WP Stainless steel for springs ○ - - ○ ○ Coil springs requiring corrosion resistance Same as above
SUP6 Silicon-manganese steel ○ - - - - Small coil springs for general machinery Hot forming
SUP9A Manganese-chromium steel ○ - - - - Medium to large coil springs for general machinery Same as above
SK4 Carbon steel ○ - - - - For general and economical disc springs -
SUS304 Stainless steel ○ - - ○ ○ Leaf springs and disc springs requiring corrosion resistance -
[Table 2] Characteristics of plastic springs
Advantages Disadvantages
-Capable of forming a complex shape
-Lightweight and rust-free
-Flexible and slightly elastic
-Decoration such as coloring can be added
-Low strength
-Low surface hardness
-Low heat resistance
-No support stiffness
  Based on the characteristics summarized in [Table 2], plastic springs are adopted for fixing hooks used with tubes and electrical wires.
