July 2010 Archives
#051 The Importance of Design in LCA
The LCA project's success or failure is largely determined by the result of design process of conceptualizing to creating the manufacturing drawings. To "Design" is for the designer to create all the necessary information (LCA performance, manufacturing drawings, operation instruction information) of the LCA project to be built. A flow of design to LCA completion is as [Fig.1] below.
[Table.1] Relationship of LCA design and LCA cost reduction
Cost reduction on procured items(1) Frequent application of VR design approach to Fixed sections.
(2) Use interchangeable designs to prevent idling parts to reduce LCC.
(3) Selecting "adequate" specifications (avoid excessive specifications).
Cost reduction on manufactured items(4) Designs to reduce manufacturing costs (material selections, shapes. tolerances, etc.)
(5) Designs with fewer parts.
Cost reduction on assembly/maintenance(6) Easy to assemble designs (assembly datums, directions, shared parts, etc.).
(7) Easy to disassemble/repair design, etc.
The LCA design process begins with a conceptualizing of functions with illustrations, then proceeds to design drawing and manufacturing drawing creations. To this point is a process of turning the abstract ideas into drawing information.
After the drawings are created, parts are manufactured and purchased components are procured according to the drawings, then on to assembly work and programming. All of these steps are executed according to the contents of the design. Therefore, it can be said that a good LCA depends on a good design.
A manufacturing system including LCAs are composed of purchased parts such as screws and springs, purchased machine elements such as motors, etc., and machined components made of raw materials (including control programs). Cost reduction ideas for each, as well as assembly/maintenance cost reduction ideas can be summarized in a table above. It can also be seen from this table that the quality of design largely affects the success rate of LCA.
#050 About Good "Wide Variety Small Volume Production" Designs
Let us take a look at the aspect of LCA designs in regard to "Wide Variety Small Volume" production lines.
We'll begin with sorting of the design process and a flow. [see Fig. 1] "Designing" is a process of decision making (on LCA performance, manufacturing drawings, and information on how to operate) to create "Something" when a need to materialize such "Something" arises. If the design process is commenced forward without giving the proper thoughts, separate design drawings would be need for every production item and the amount of work required will increase exponentially. In actuality, businesses are offering wider variety of products.
[Fig. 1] Fundamental Design Process
For this diversifying needs, there is a design approach called VR (Variety Reduction)
[Table] VR Design Approach
ExplanationA) "Fixed-Variable" Design ApproachB) "Combination" Design Approach
1. Fixed section is composed of a basic specification enabling unit.
2. Variable sections cope with the variety of production items.
3. Fixed + Variable format copes with wide variety production.
1. LCA is expanded into Product/Units/Parts layers.
2. Simplify the Parts and Units into interchangeable design.
3. Combinations of Units and Parts to cope with the wide variety production.
ExamplesThe World Car concept enables the wide variety production scheme by designing the platform (basic body/chassis) as the Fixed section, regional market dependent exterior/interior/accessories as the Variable sections.In a case for Mountain Bikes, the frame and other accessories can be selected to fit the rider to achieve individualized customer fulfillment per product.
LCAFixed section = Base machine
Programming
I/O spec., etc
Variable section = Work holders
Tool units, etc
Linear guides, slide units, etc
- Single axis slide units
- Two axes (XY) slide units
- Interchangeability of above
#049 About Good Designs
In order to execute effective LCA, the concept of "Good Designs" needs to be first understood, before a good plan can be constructed.
Let us think about "Good LCA Designs"
The closest critics on any LCA machines or jigs are the operators who use the manufacturing systems on factory floors. Therefore, the most sought aptitude for an LCA Designer would be an ability to present "good" suggestions or proposals to those operators. Such aptitude would be backed up by the following.
1. Adequate product knowledge
2. Complete understanding on manufacturing processes and operation details
3. Ability to understand product cost structure
4. Sufficient knowledge (or understanding) on relevant manufacturing technology
The meaning of a word "Good" has revolved and evolved over the years as the industrial era phases have. Since the twilight time of the industrial automation age, a unit of measurement for the success has been a Corporate Principle driven return on investment, or cost vs. performance. But in recent times, socioecological parameters (i.e. effects on industrial waste management costs) are also being included. A prominent example of the above is Life Cycle Cost (LCC: see Notes-1).
※Notes-1
LCC: Life Cycle Cost
A concept of evaluating the total cost of an equipment from development/manufacturing to decommissioning/disposal. Quantitative measurement is calculated by the following.
Therefore, the LCA designer must devise effective designs taking in consideration the needs of the surrounding operators as well the socioecological factors. The functional keywords in "Good"LCA can be consummated as below.
Required LCA functionality
(VQCDPSL)
Aim for "Good" LCA
V: LCA functionality of "Value"LCA that keeps specification variation to a minimum.
Q: LCA functionality of "Quality"LCA that achieves zero defects
C: LCA functionality of "Cost"LCA that depreciates less.
D: LCA functionality of "Timing (delivery)"LCA LCA that can respond to product changeover.
P: LCA functionality of "Productivity"LCA that is easy to use, and easy to setup change.
S: LCA functionality of "Safety"LCA Safe to use LCA
L: LCA with high ratio in "Cost vs. Performance"LCA Low maintenance and disposal costs.
#048 Motion Mechanism Design - 18 : Connecting a Motor Shaft and Ballscrew
Dimension specification for the three parts related to assembly accuracy previously identified in #047 is explained.
(1) Meaning of "matching the assembly datum of the parts"...
(2) Method of dimension specifying for each part. (see [Fig.1] and [Fig.2])
By designing with dimension specifying datum surfaces on all parts to be coincided, post assembly accuracy can be assured. This design scheme utilizes three parts each with datum surface A, A', and A" to assure the assembly accuracy of X axis and Y axis.
In order to benefit from this dimensioning specification methods to realize low cost (can be assembles without highly trained labor) machines, the designer is required of the following.
1. Able to understand the assembly process.
2. Knows how the parts are machined.
3. Able to properly: specify dimensions, specify tolerances, specify part fitting.
[Fig.1]
[Fig.1]
This page is an archive of entries from July 2010 listed from newest to oldest.
June 2010 is the previous archive.
August 2010 is the next archive.
