January 2011 Archives
#064 Air Cylinder Selection Basics
Selection key points on air cylinders for LCA designs are organized and shown below.
(1) Checkpoints on Air Cylinder Selections
CheckpointsEvaluation Parameters
1Actuation directionSingle action type, Dual action type
2Linear motion or oscillating motionSelection of support type (Clevis, Flange, etc.)
3Required actuation forceCylinder bore diameter , Applied air pressure
4Load travel distanceCylinder stroke (Cylinder buckling limit stroke)
5Load travel velocityValve size, Plumbing size
6Shock force at stroke endsCushion (Evaluation of cushion effects)
7Operation environment temperature range (5~60°C or less?)Gasket material
8Surrounding environment (dusts, cutting chips & fluids)Protective cover
9Possibilities for corrosionsCorrosion resistant cylinders (surface coated cylinders, corrosion resistant materials
Cylinder force is determined by piston diameter and air pressure used. (See [Fig.1])
(2) Air Cylinder Force Calculation
(a) Checkpoints on Air Cylinder Selection - Dual Action Cylinders
[Fig.1] Dual Action Cylinder Construction
Effective Force of an Air Cylinder  FA=F・μ=(A・P)×μ
   FA:Effective Force [N]
   F :Theoretical Force [N]
   P:Applied Pressure [MPa]
   A:Piston Pressure Area [mm2]
   μ:Cylinder Force Efficiency [%]
(b)Single Action Cylinders
The value is a sum of dual action cylinder force and the internal spring force (for positive or negative pressure).
Force of Single Action Push Cylinder (See [Fig.2])
  Force FPUSH=π/4×(D2・P・μ)−(Spring Return Force)
  D:Cylinder Diameter [mm]
[Fig.2] Single Action Push Cylinder Construction
Force of Single Action Pull Cylinder
  Force FPULL=π/4×((D2--d2)・P・μ)−(Spring Return Force)
  d: Piston Rod Diameter
(3) Efficiency of Cylinder
The force generated with compressed air would be less than the theoretical force due to internal friction force, etc. Select cylinders based on cylinder force efficiency μ=approx. 50% for applied air pressure of 0.3MPa or more.
(4) Allowable Lateral Load
If lateral loads are applied on the piston rod, gouging can occur due to increased contact pressure on cylinder head bushing and cylinder tube inner wall. For max. lateral load limit, use 1/20 of cylinder max. force (μ=100%) for calculations.
#063 Troubles and Countermeasures for Air Cylinder Selections
In this discussion, pneumatic system component selection troubles and countermeasures are explained based on an example of "Unstable Actuation Time".
Following causes are conceivable for unstable air cylinder actuation time.
1. Supplied air pressure and volume
2. Increase of cylinder internal resistances
3. Load rate on air cylinders
4. Cushion function of air cylinders
5. External resistances and structural influences
The item 3. and 4. are explained here
(3) Problems caused by air cylinder load rates and countermeasures
The Load Rate is a rate of cylinder force capacity vs. applied load (W), and represented by the following formula.
  Load Rate α = Applied Load (W) / Air Cylinder Force (F)
  Air Cylinder Force (F) = π / 4 x D2 x P x μ[Kgf]
    D: Cylinder DIA. [mm]
    P: Applied Air Pressure [MPa]
    μ: Cylinder Force Efficiency [%]
When assimilating the instability of air cylinder actuation time with performance instability of automobiles, the cylinder force would be analogous to engine horsepower, and applied cylinder load to automobile weight. It can be understood that an automobile (air cylinder) must have appropriate power to weight ratio. The key point on LCA designing is to reduce (enlighten) applied loads.
Countermeasures for Load Ratio Related Problems
・Use air cylinders at as high a pressure as possible
・Select the largest cylinder bore diameter
(4) Countermeasures for Cushion Function Related Problems
There are air cylinders with and without cushions. In cases when a) applied loads are high, and/or b) operation speeds are high, the cushion function can degrade due to repeated usage and cylinder operation can become unstable.
(a) When the applied load is high
Kinetic energy can be obtained by the following formula. When E exceeds the air cushion capacity (shock absorber's max. energy absorbing capacity), a cylinder with one rank higher bore diameter should be selected.
  Kinetic Energy E = 1 / 1960 x (Load [Kgf] x Velocity2[cm/s]
(b) When the velocity is high
Same principle as the case of high loads. Select a cylinder with one rank higher bore diameter.
Countermeasure for Cushion Related Problems
・Select a cylinder with one rank higher bore diameter for both High Load and High Speed cases.
This page is an archive of entries from January 2011 listed from newest to oldest.
December 2010 is the previous archive.
February 2011 is the next archive.
