February 2013 Archives
Surface mount components such as capacitors and insertion parts for assembly need to be top/bottom and for/aft orientation aligned. The orientation alignment will be based on the unique characteristics of the subject components (shape differences, identification markings, and etc.).
Explanation on For/Aft orientation alignment
(1) When there are differences in front end and rear end shapes
The directional alignment is often performed utilizing the for/aft shape differences of the parts.
a) Movement of a part not requiring directional changes
b) Movement of a part requiring directional changes
(2) Parts feeding and aligning
-Small parts such as shown in the above example are randomly put in a funnel shaped vessel called "Hopper".
-This Hopper is vibrated finely to perform parts orientation change operation on the "Alignment feeder".
-There are following three vibratory methods for the Hopper. The vibratory hopper is also called Parts Feeder.
-A vibrator unit is mounted below the hopper to make up the parts feeder.
-The round hopper is sometimes called a Bowl.
Difficulty level of the component alignment technology rises as the component sizes are on the miniaturization trend. The following aligning processes are needed in order to align components, and the automation measures to orientation rotate chip components of around 0.5mm is a highly advanced technology that is an accumulation of Low Cost Automation technology over a long period of time.
-Relationship of part's pivot point and center of gravity (CG), and shift distance of CG are related to component alignment. For the component shape shown on the left side in the below diagram, 90 degree orientation change by compressed air is relatively easy.
■Miniaturization・Shape changes
-As shown on the left in the diagram below, a measure to change the orientation of small capacitor easier by devising a shape to retain the component. (Patents are applied for by the manufacturers of automated chip aligning machines.)
-In this case, the pivot point on the capacitor does not move, facilitating a smooth orientation reversal.
LCA (Low Cost Automation) for aligning small parts such as capacitors require the following performance characters.
■ Performance required for capacitor alignment LCA technology
Mounter is not to be stopped←High speed aligning, Zero alignment errors, Zero arts jams, Work damage free
-The parts feeder component alignment technology has been a mature technology since the industrial automation became popular since early1970s. But miniaturization of the parts to be aligned has increased the difficulty levels of alignment methods.
-For parts aligning, positional relationship of part's center of gravity and pivot point as well as movement distance of the center of gravity come into play.
Correct orientation,Position requiring re-orientation,State of re-orientation
-The pivot point movement distance becomes larger but the center of gravity movement distance becomes smaller as the capacitor size becomes smaller, and the re-orientation will be more difficult. Such alignment technology will be the know-how of each manufacturer.
Capacitors as the representative chip style electronic component example, component alignment technology is explained. For smaller, lighter, and thinner electronic equipment, capacitors have been changing in miniaturization and minimization of the product configurations.
[Table 1] Changes in projection area and volume of capacitor products.
Capacitor size (L-W)321621251608100506030402
Projection area ratio (%)100 (Setting)48.8259.83.51.6
Volume ratio (%)100 (Setting)38.112.53.10.70.2
Weight (mg)30mg165.71.20.30.1
[Fig.1] Capacitor size component,  [Fig.2] Transition graph of capacitor projection area and volume
-As can be seen from [Fig.2], miniaturization of capacitors contributes to size and weight reduction of 1/62 projection area, 1/500 volume, and 1/300 weight.
-However, difficulty levels in the automation technology to detect capacitor component orientation and position manipulation will rise.
-For the capacitor component alignment tasks, parts feeders are often used to perform the process.
 a) Side reversals
 b) Fore/aft alignment
 c) Workpiece separation (rejection of misaligned parts, etc.)
Linear feeder alignment by NTN (Corp.)
This page is an archive of entries from February 2013 listed from newest to oldest.
January 2013 is the previous archive.
March 2013 is the next archive.
