November 2012 Archives
One of the important achievements of the automation is to stablize the production quality of products at high levels. In addition, there are other manufacturing processes that are quality improved by secondary effect of automation ([Fig.1]). In this session, the latter case will be explained.
[Fig.1] Relationship of Automation/Low cost automation and Quality
Example description: Automating a molded product extraction of plastic injection molding process
- With plastic injection molding, the molded plastic products are produced by injecting melted plastic into metal molds, then plasticized by cooling down.
- For the molding processs, a plastic injection molding machine ([Fig.2]) and a mold ([Fig.3]) are used.
- By replacing the molded plastic product extraction process from human work to extraction robot automation, injection molding quality can often be improved.
[Fig.2] Plastic Injection Molding Machine
(From: Nissei Jyushi Kogyo Corp. HP)
[Fig.3] Example of a mold
[Fig.4] Effects of automating injection molded plastic product extraction
#137 Specail Edition : Bio-machine
Since its starting in 2001, the 1st year of the 21st century, the Low Cost Automation Technology Course has reached the Vol. 400. Our environment has changed largely in these 8 years. The investment monies have flowed into oil and other resources, the automotive society has changed with soaring gasoline prices, hybrid automobiles have resurfaced in popularity, and further advent of electric and hydrogen fueled cars are awaited.
If the first decade of the 21st century is denoted with a representative technology reformation of gasoline combustion energy and rolling friction to clean energy and rolling friction, bio-mechanisms would be in utilization by the last decade of the 21st century.
- [Fig.1] is a bacteria.
- [Fig.2] is an explanation of this bacteria's motion method where it moves in swimming-like motion with its rotating filaments.
- [Fig.3] mechanically explains the bacteria's cellular structure of rotating filaments.
- It has a similar structure with automated machinery: Bearing=Rings, Coupling=Hook, Drive shaft=Filament, Enclosure=Membrane would represent structural components of today's automated machinery.
Problems such as friction and wear may not present any issues on life problem as they do today due to its biochemical effects.
[Fig.1] Typical Bacteria 1)
[Fig.2] Bacteria's Motion Method 1)
[Fig.3] Drive structure figure of bacteria's filament 1)
source:1) MICROBIOLOGY, The Benjamin/Cummings Publishing Company, Inc.
#136 Mastering Ball Screws - 6 : Life of Ball Screws
Since the ball screws are designed based on rolling steel ball bearings, product service life calculations are backed by a solid theoretical system.
(1) Life of rolling ball bearings
-Here, we consider the ball screw life based on them as being analogous to the general purpose ball bearings. There are following 5 items as representative functionalities of ball bearings.
(1) Little friction
(2) Smooth rotation and quiet
(3) Good accuracies
(4) High load bearing capability
(5) High rigidity
-The life (in a broad sense) can be defined as an ability to retain these functionalities (durability).
-Various defects, damages, and deterioration (accuracy degradation, noise increase, torque increase, and wear, etc.) are what degrade the ability to retain the functionalities.
-Noise and torque increses are often attributed to ball screw systems designs, handling, and installation accuracies.
-However, the Flaking caused by rolling fatigue can occur even with proper designing and installing, and the JIS defines this as Life in a narrow sense.
■Bearing life definition in a narrow sense
The total number of rotations until the bearing race or rolling body will show fatigue induced material damages.
(2) Life of a typical ball screw (Life in a narrow sense)
Other than ball screws with high preloads, the typical ball screw life can be approximately determined by the following calculation formula (07 MISUMI Catalog, P2532)
#135 Mastering Ball Screws - 5 : Noise Reduction of Ball Screws
Increased demand for the ball screw noise reduction is due to, not only to the conventional production factory environments, but increased ball screw applications in quiet environments (low noise levels) such as offices, hospitals, and food production lines. Furthermore, ball screw noise reduction links to improved functionalities such as energy savings and extended operational life, thus it is inevitable for performance increase.
(1) About ball screw noise reduction
Comparisons are made below between the construction and noise generating conditions of rolling ball bearings, rolling ball bearing style linear guides, and ball screws.
Structural differences
(2) Noise source (= vibration source) of ball screws
- Ball screw noise source (= vibration source) is due to the following structural problems.
Ball screw noise source (= vibration source)Type of noise
a) Complex ball recirculation pathsBall collision noises
b) Screw shaft groove surface roughness and surface wavinessChattering sounds
c) Shaft vibrations from bending and concentricity errorsSqueaking noises by abnormal steel ball sliding
d) Groove shape accuracy (bending, unevenness of groove shape) Squeaking noises by abnormal steel ball sliding
e) Screw shaft and nut installation errorsSqueaking noises by abnormal steel ball sliding
-Ball screw noise is generally defined with an empirical formula: Noise is proportional to the Log of the product of ball diameter dm and screw shaft rotation n. Therefore, the principle measures are reducing the ball diameter and reducing the operational speeds.
-For this reason, using large screw leads to lower the rotational speeds can effectively reduce the ball screw noises even at high linear speed operations.
(3) Noise reduction measures as a mechanical system
-Since the ball screws are installed as components on automation machinery, the noise level is determined by the countermeasures applied to the entire automated machine system. By this countermeasure, the overall noise reduction effect can be obtained.
- The following items can be listed as the representative factors of mechanical system noise.
(1) Lack of mechanical system rigidity (static and dynamic)
(2) Structural characteristics such as sound trapping covers
(3) Lack of countermeasures on individual vibration source adding up to enhanced vibration transmission and resonaces.
This page is an archive of entries from November 2012 listed from newest to oldest.
October 2012 is the previous archive.
December 2012 is the next archive.
