November 2009 Archives
#021 Motion Mechanism Design
Simple automation machinery (LCA) are comprised of the following.
The tutorial explanations to this point have been centered around usage points on mechanisms and machine element components. From this point forward, mechanism designs on 1. LCA that can operate at higher speeds, and 2. LCA that can repetitively operate programmed movements over long time durations will be explained.
(1) Motion mechanism designs and related engineering
The mechanisms introduced as "Essence of Karakuri fixtures (LCA Tutorial #79~)" are encompassed within the concerns of Mechanism Engineering. There, the design tasks can be carried out with only concerns on "balancing of forces", without any considerations for high speed operation related matters. For designing mechanisms capable of complex controlled motion at high speeds, the designer should be well oriented with Mechanics and Machine Vibration. If machined part strength or actuator selections and such are evaluated on these grounds failures can be reduced, and even the failures can be reengineered for further enlightenments.
[Fig.1] shows the engineering disciplines related to motion mechanism design.
#020 Locating Pin Configurations and Fits
When designing automated assembly systems using a various fixtures, careful considerations for shaft/bore fits along with locating pin/hole shapes and configurations are needed.
Principles of locating feature designs
*Adequately chamfer the pins holes to facilitate smooth pin entry.
*Two constraint points cannot simultaneously exist per one insertion action.
*Extraction action must also be considered when designing.
[Fig.1] shows typical configurations of locating pins and locating holes. Subjects related to the locating parts are as follows.
1. Required position locating accuracy.
2. Assembler/apparatus accuracy.
(Degree of work difficulty or ease, etc.. Machine accuracy.)
3. Assembled parts accuracy.
(Case of high accuracy parts, or variable accuracy parts, etc.)
4. Workability of parts such as contacting surface length, etc.
(Relationship between produceability and accuracy, etc)
[Fig.1] <a href=Locating pins / Example of concentricity error and pin shapes" name="image" width="527" height="240" />
Locating pin/hole design in [Fig.1] is to be proceeded with the following.
Locating pins
Taper angle(θ)10~30° for automated assembly requiring accuracy, and manual assembly in low workability conditions.
30~60° for manual assembly in good workability conditions.
Length of taper(EO)Calculate based on the pin/hole concentricity error (e) amount. (Related to the shaft dia. and tip guide dia.)
Locating guide length(L)The length (L) is calculated based on workability and desired reliability of machines. (see [Fig.2])
[Fig.2] Relationship of workability and locating pin shapes
Locating holes
Guide chamfering(C)Specify chamfering for the entry side of the locating holes.
Hole drilling accuracyIf needed, specify hole perpendicularity and other parameters on the holes in relation to part's datum line.
#019 Selection of Bearing Fits
Rotary bearings are machine elements that support rotating shafts accurately while providing low friction condition. In order to obtain stable bearing performances over prolonged duration, appropriate bearing fit design considerations are required to avoid any negative effects ([Chart 1]) that may arise from bearings' rotary operation.
[Chart 1] Designs for bearing fit and issues to be solved
Bearing mechanism issuesResultant behaviorsCountermeasure example
Temperature rise due to high speed rotation.Shaft diameter expansion causing moment loads, resulting in bearing seizure, uneven wear, and damages.Choose fitting dimensions with shaft expansion anticipated.
Thrust and radial direction clearance variations occurring from applied loads.Degradation of rotational accuracy. Abnormal noises.Choose fitting dimensions with clearance increase anticipated under load.
Design examples of rotary bearing application.
An example used here is based on "Inner race rotation : Outer race retained" arrangement shown in [Fig.1].
[Fig.1] Example - Inner race rotation : Outer race retained (loading in one direction)
Selection of bearing fits based on shaft diameter
Transition fit or interference fit is selected to ensure the shaft and the inner ring will always rotate together.
[Chart 2] Selection example of fits (case for radial bearings)
Shaft/bearing fitsApplicable for:Fitting standards
Transition fitFor light loads.
For varying loads.
h5, js6, k6, etc.
Interference fitFor general applicationsjs5, k5, m5, m6, etc.
Selection of fits for bearing holder bores
Clearance fit should be chosen for ease of assembly while preventing any deformation of bearings' outer/inner races. In general, [Clearance fit] (H7) is used. In case of light loading applications (H8) can be used, or (G7) when large temperature variations are to be considered.
[Chart 3] Fit selection examples for bores (case for radial bearings)
Bore fit selectionApplicable for:Fitting standards
Clearance fit.General rotation applications.H7
Same as above.Light loads.H8 (wider tolerance than H7)
Same as above.Large operational temp. rise.G7 (large clearance)
#018 Sensor Mounting - 2
Proximity sensors can be: magnetic (reed switch type), high frequency oscillation, capacitive types. The sensors are offered in a various form factor such as rectangular, cylindrical, through-hole styles, and the popular cylindrical types are threaded on the outer body to facilitate easy adjustments.
Proximity sensor mounting
(1) Characteristics and detection distance of proximity sensors
Prox. sensor type Detection distance, characteristics, etc.
High frequency oscillation type
・Detection distance varies with the sensor's sensing surface area size and shielding methods (shielded or not shielded). For actual applications, use within 70% of the max. distance shown in product specifications to assure ample detection sensitivity.
・Detection distance will vary with target material. Take iron/steel as 100 (std. ref.), the detection sensitivity would be: stainless steel approx. 70%, aluminum 30~40%, copper approx. 30%.
・All metals can be detected.
Magnetic
(Reed switch type)
・Can only detect magnetically permeable objects. Detection distance: 4~50mm
・Low cost since they require no power supply.
・Shortcomings: slow response, cable length limitations
Capacitive type
(Differential transformer type)
・Can detect magnetically permeable objects. Detection distance: 0~40mm
(2) Cylindrical proximity sensor mounting examples
[Fig.1] shows an example of proximity sensor mounting using a shaft collar (4-hole type) and a mounting bracket.
[Fig.2] is an example using a post clamp.
[Fig.1,2]
This page is an archive of entries from November 2009 listed from newest to oldest.
October 2009 is the previous archive.
December 2009 is the next archive.
