October 2009 Archives
#017 Sensor Mounting - 1
Sensors are used to control positions and speed of the actuators used in automation designs. In order to achieve proper functional sensitivity from the sensors, placement of the sensors become important.
Sensor types and mounting methods
(1) Sensor types and definition
Definition of a sensor is as follows.
Sensors must be placed properly to detect the physical occurrences (presence of objects, speed, pressure variations, etc.) accurately.
(2) Position detection sensor types and points on location adjustments.
 Position detection sensors are following types.
(3) Position detection sensor mounting
・For a single axis linear motion system, an end-of-travel limit switch at each stroke end, and a home position limit switch will be used.
Use a [1] Sensor rail and [2] Bar nuts to mount the sensors. See [Fig. 1] and [Photo 1] for usage examples. image
・[Photo 2] shows an arrangement of position sensors/sensor rails/bar nuts for a 2-axis XY table.
#016 Application Examples on Connecting with Linear Motion Components
Introduced here are some methods for connecting air cylinder piston rods to moving objects.
Methods for connecting air cylinder piston rods.
(1) Principles of connecting linear motion mechanisms.
Following two types are the most popular representatives of linear motion drive train.
・The rotary to linear type has a coupling that absorbs wobbles, and transmits the needed rotary to linear motion.
・For the linear to linear connection scheme, a Floating Joint is used to connect the air cylinder and the moving object. Play in the floating joint provides the same function of the couplings.
・If the air cylinder and the moving body are connected without the use of a floating joint, damages may result on the air cylinder's piston seals due to excessive direct forces applied upon the seals.
(2) Application examples of Floating Joints
[Fig. 1] shows a standard methods of a floating joint connection.
[Fig. 1]
[Fig.2] illustrates the assembly of the floating joint. The floating joint is composed of the holder, nut, ring, and bolt. There is some margin between the space inside the holder and the nut.
[Fig. 2]
[Fig. 3] & [Photo 1] are application examples of Flange Mount Type Floating Joints.
#015 Usage Examples of Hinge Pins
Introduced here are some examples of connecting two machine elements together. We have discussed some connection methods for rotating shafts. Here, the discussions will cover some cases on connecting two elements where one is stationary and the other will be moveable.
(1) Connecting Hinge Pins
(1) What is a Hinge?
A hinge is a mechanical element composed of two parts where one is fixed stationary and the other is able to pivot freely. A hinge can be configured using Hinge Pins.
(2) Connecting methods using Hinge Pins.
There are following types.
The Hinge Pins are manufactured with "g6" O.D. tolerance. Mating bores should be made with H7 tolerance to achieve "Slip Fit" connections.
(3) Hints on selecting the connection methods
Evaluate the following check list against the applicable mechanism characteristics to select a proper connection method.
a) The hinge pin and axial force relationship
Hinge pin retaining strength against the axial force would be as follows.
(Low strength) Cotter pin < Retaining ring < Retaining screw < Nut retained < Female thread < Key retained (High strength)
b)Hinge pin replacement frequency
Cotter pins are one-time use only, cannot be reused.
Key retained type is somewhat cumbersome to work on.
Other methods render for easy replacement.
c) An end of the hinge pin can be grasped or not.
If an end of the hinge pin cannot be grasped due to design constraints or there is a width constraints, the retaining screws or the key retained types can be employed.
(4) Cautionary points on connecting.
・When using cotter pins, bend the pin at a proper length to avoid snagging on the rotation section.
Connection methods for linear motion components, next.
#014 Usage examples of Locating pins / Guide : Locating of Various Types of Work
Locating techniques are shown here with silicon wafers (thin round disc) and printed circuit boards (thin rectangular boards) as examples.
(1) Hints on how to determine the locating techniques
By properly selecting the following criteria, locating techniques for a variety of work can be determined.
a)Select locating pin material and shapes based on understanding the work's specific characteristics.
example: hard, soft, easily scratched, easily cracked/broken, deformed/warped, electro-statically damageable, cannot be tested ...
b)Determine if the work itself possesses any reference feature.
example: has pilot holes for locating, and the holes are indexable from the reference feature
c)Select locating pins/guides that match the methods for in and out-feed of work.
(2) Examples of locating various work pieces
Example - 1: Locating silicon wafers
[Fig.1] Locating silicon wafers
Characteristics of the work piece
・Thin disc shape with a partial notch.
・Material is hard, and the disc's side could cause wears on the location pins.
・Used in clean environment and cannot tolerate rust.
・Tips is spherical shaped.
・Tip is spherical shaped.
・Work is located on it's sides.
In-feed and out-feed method
・Work is automatically located so only the top side needs to be open for access.
Example - 2: Locating a PC board with pilot holes
[Fig. 2] Locating a PC board with pilot holes
・The work piece contains glass fiber and the locating pins will gradually wear.
・Select locating pins that match the pilot holes.
・Use a design that makes locating pin replacement possible.
・Provide a slot on the fixture (work efficiency)
Locating reference
・Locating holes provided on the PC board.
in-feed and out-feed methods
・Give considerations to improved work efficiency since the operation will be manually performed.
Example - 3: Locating a PC board without pilot holes
[Fig. 3] Locating a PC board without pilot holes
・ame as Example - 2
・Use plastic to avoid short circuits and electrostatic damages.
・Select "Work Guides" as the locating method.
・Select plastic for "Work Guides" material.
・(Others omitted)
Locating reference
・Select "Work Guides" instead of pins since the PC board is located on external features.
In-feed and out-feed methods
・(Omitted)
This page is an archive of entries from October 2009 listed from newest to oldest.
September 2009 is the previous archive.
November 2009 is the next archive.
