May 2014 Archives
In relation to higher value adding trends in Japan's manufacturing fields, the importance of vibration problems are on the increase. Since increased speeds and higher precision in devices that have masses are physical phenomena in contradictory relationship, high levels of control technology and vibration isolation technology must be utilized. Hereafter, vibration problems on automation and countermeasures will be explained.
1) Problems of vibrations and manufacturing field
In manufacturing fields, quality, costs, and vibration problems are in strong direct and indirect relationships.
Examples:
(1) If vibration reduction measures are not applied, accurate positioning and print quality stabilization will not be possible.
(2) Production cycle time needs to be shortened, but vibrations will increase.
(3)The defect rates are different due to the vibration differences during the day and night.
(4) When trucks pass on the road outside, vibration transmissions cause uneven resist printing.
Therefore, for the designs of production equipment with higher added value, appropriate vibration countermeasures will need to be implemented at the initial phase of the designing.
Applying anti-vibration measures on equipment and factories that are already built often produces smaller results than the efforts applied. The principle is "Proper anti-vibration measures begin at the start".
2) About anti-vibration mounts
Anti-vibration mounts ([Photo 1]) are used to reduce vibrations on machines such as component insertion machines and press-fit machines, or in isolating external vibrations to the machines.
[Photo 2] is a frequency based evaluation of an anti-vibration mount. MISUMI anti-vibration mounts can be utilized for effective vibration countermeasure.
[Photo 1] Representative anti-vibration mounts
[Photo 2] Evaluation of vibration damping characteristics of a anti-vibration mount
Assembly of shafts and holes can be classified into 2 types based on the dimensional relationships of 2 parts parts to be mated.
Here, the terminologies of press fitting that require forces.
[Table 1] Press fit operations and terminology explanations
Press fitting terminology Terminology explanation and example
Static press fit Insertion with static forces without impacts.
EX.: For press punches on die & mold
Vibratory press fit Press fitting with vibrations applied.
EX.: Light press fitting for easily damaged components, etc.
Impact press fit Press fitting with impacts.
EX.: Press fitting of dowel pins and locating pins.
Push fit For O-rings, gaskets and springs where the components are push fit along shafts.
EX.: E type retaining rings, press fitting of bearings on pillow blocks.
Shrink fit Fitting shafts into holes by heat expanding the holes.
EX.: Press fits requiring high precision and high torque capacities such as shrink press fitting of rotating tools (End mills, etc.) onto tool holders, mounting of drive gear rims onto hubs.
Cold press fit Reverse of the above where the shafts are made smaller by cooling to be inserted.
EX.:
・To avoid the press fitting damage for the large and fragile parts.
・Fitting of bearing bushings.
Explanations of press fitting process
Press fitting is a process where 2 parts are press assembled with a targeted amount of interference between the shaft diameter and the hole diameter.
Insertion forces amounting the surface pressure and friction of creating the interference must be applied. The press fitting can be classified based on how these forces are applied.
Press fitting processes require some preparations with high levels of difficulty such as reliable locating and part holding of the components, but reliable bonding of the parts can be obtained without adhesives according to the press fitting forces applied.
This page is an archive of entries from May 2014 listed from newest to oldest.
April 2014 is the previous archive.
June 2014 is the next archive.
