July 2013 Archives
(1) Units comprising in-mold assembly LCA
The in-mold assembly LCAs are comprised of the following units.
a)Linear motion unit (Up/Down direction)
b)Linear motion unit (Fore/Aft direction)
c)Crimping/Swaging/Press unit
d)Positioning unit←
e)Linear actuator
f)Posts
(2) Example of positioning unit construction
- In the case of in-mold assembly LCA, following three positioning units will be needed.
1) Workpiece positioning
2) Fore/Aft unit positioning
3) Up/Down unit positioning
-These three positioning units are selected based on load weight, accuracy, and concerns for scratches, etc.
(1) Basic type of positioning
-Anti-wear measures over long period of usage are important for the positioning system to prevent locating/positioning accuracy degradation.
-The positioning basic is a set of locating bushings and locating pins with anti-wear measures applied.
[Fig.1] Example of Pick & Place positioning unit mechanism
(2) Workpiece positioning and Up/Down direction positioning example
■Explanation
-Select the locating pins (JPS) and locating bushings to make the spacing between the fixture plates as designed.
-In this condition, the resin type locating pins (MJP) are to hold down the PCB at four corners.
-The PCB is position located with 3 locating pins.
-The additional work and inspection are applied through the opening located in the center of the top fixture plate.
b)Linear motion unit (Fore/Aft direction)←
d)Positioning unit
e)Linear actuator
f)Posts
(2) Linear motion unit (Fore/Aft) construction example
For fore/aft positioning, position adjustments may be required in order to make it compatible for multiple setups.
Here, mechanism examples of easy to adjust fore/aft direction positioning are introduced.
(a) Multi-setup compatible manual linear motion unit
For the position adjustment mechanism of a linear motion actuator that has moving locating blocks, an adjustment mechanism with a stopper adjustment screw is used.
[Fig.1] Example of a linear motion unit positioning stopper, [Fig.2] Example of a position adjustment mechanism
(b) Multi-setup compatibility of locating carrier
For position adjustments of carriers and fixtures that do not have positioning actuators, the locating blocks are directly position adjusted by using adjusting bolts.
[Fig.3] Example of a position adjustment mechanism of locating carrier
This page is an archive of entries from July 2013 listed from newest to oldest.
June 2013 is the previous archive.
August 2013 is the next archive.
