June 2012 Archives
When automating assembly that was once performed manually (low-cost automation), mechanical designers tend to forget the expertise involved in manual processes. Complex mechanisms and controls are required in order to replicate this expertise using automated technology, resulting in disadvantages such as: (1) lengthened production takt time; (2) increased failure stoppage of automated equipment; and (3) increased investment expenditures. This tutorial describes the key considerations for part design that allows the need for expertise in insertion assembly to be minimized.
(1)Key considerations for part design for easy insertion assembly
In order to improve the competitiveness of automated assembly equipment, designers of automated equipment must provide product designers with guidance regarding part design that will provide for easy assembly, as well as displaying leadership in understanding the importance of such design. The following table summarizes the key considerations.
Key considerations for part shape for easy insertion assemblyExample no.
Chamfer (round off, taper) the edges of insertion holes.[Photo 1] (1)
Chamfer edges so that the chamfering is larger than the positional deviation error of the insertion hole.
Use a guide shape (chamfering, reduced shaft diameter) on the tip of the shaft to be inserted as well.[Photo 1] (2)
Design so that the axis of the insertion assembly hole is parallel to the part's retained datum plane.
Use strength, hardness, and other material properties to make the parts involved in insertion assembly difficult to deform.
Ensure that where two insertion assembly part surfaces meet, they can slide against each other easily (due to smoothness, etc.).
Ensure that the restriction length for achieving positioning accuracy is no longer than necessary.[Photo 1] (2)
If press fitting, design so that the interference is less than the elastic deformation.
Design part shapes so that the form accuracy of an insertion assembly hole and inserted shaft can be easily measured.
Design products in a way allowing insertion assembly to be performed from a single direction from above.[Photo 2]
Provide assembled parts with stable datum planes.
Provide insertion guides for insertion assembly holes and other locations.[Fig. 1], [Photo 3]
[Photo 1] Example of insertion hole and shaft
[Fig. 1] Example of insertion hole guide shape
[Photo 2] Example of product design allowing insertion assembly from a single direction from above
[Photo 3] Example of insertion guides at screw insertion assembly locations
This tutorial describes insertion assembly technology, our third representative example of a component technology for assembly automation.
Low-cost automation of assembly procedures consists of automating multiple simple component procedures in combination. Three representative examples of component technologies for assembly procedure automation are described in these technical tutorials: swaging technology, screw tightening technology, and insertion assembly technology.
(1) What is insertion assembly technology?
- The term "insertion assembly technology" refers to techniques for performing the following types of procedures, whether manually or using tools/machinery.
a) Inserting or press-fitting a shaft or square bar into a hole (Fig. 1)
b) Insertion assembly of irregularly shaped parts into their intended positions (Fig. 2)
- Interference fits and other press fits are insertion assembly methods enabling a range of functionality, including: (1) fixation, (2) positioning, (3) posture holding, and (4) force transmission.
- Clearance fits and other insertions are insertion assembly methods with a range of uses, including: (1) positioning, (2) guidance, (3) preprocessing such as joining, and (4) coupling.
[Fig.1][Fig.2]
(2) Characteristics of insertion assembly technology
1. Advantages
  • - Insertion assembly is suited to use as a component technology for automated assembly, because it generally involves movement in a single direction.
  • - High-precision assembly automation can be effected with ease, according to the level of precision of the parts used. (See Fig.1.)
  • - Disassembly/re-assembly is possible after assembly.
2. Disadvantages
  • - Insertion assembly is greatly affected by the design form and quality (such as precision or surface conditions) of the two individual parts to be assembled.
  • - It is extremely difficult to automate exacting procedures requiring highly skilled manual work.
  • - Disassembly is difficult if faults (such as biting) occur during insertion assembly mechanical procedures.
This page is an archive of entries from June 2012 listed from newest to oldest.
May 2012 is the previous archive.
July 2012 is the next archive.
