November 2014 Archives
#193 Design Image Training - 9: Pick and Place Parts Drawings
This component explains the part drawing of the P&P mechanism component.
The weight of the assembled parts and actuator need to be reduced because the P&P unit parts are assembled to the XY table for high-speed drive control.For this reason, aluminum materials are frequently used for the manufactured parts parts, and reinforcement measures are incorporated into the structure design of the parts such as a long arm shape.It is also important to select a lightweight actuator.
[Fig.1] Overall view of automation transfer device
To move the chuck unit vertically, two locating pins are used for the part on which the chuck unit is mounted (chuck plate: see [Fig.2]). This part is assembled into the air slide guide with these two locating pins .
[Fig.2] Chuck plate part drawing (right)
#192 Design Image Training - 8: Pick and Place Mechanism - 2
This section introduces a photo and drawings to explain the P&P mechanism section, which is different from the Bingo Machine.
- Aluminum materials are frequently used for the P&P unit components because their weight needs to be reduced.This unit is manufactured by using A5052.The hand part is made of plastic.
- For the linear actuator, we adopted the pneumatic pico table (Misumi MPPT16-30-RS) for its lightweight and compact properties.
- The component (chuck plate: see photo) used to mount the chuck unit is assembled onto the pico table.
- A pneumatic type is also adopted for the chuck unit, and plastic chuck fingers are assembled onto it.
[Photo 1] P&P unit of automation transfer device
Front view of the P&P mechanism section
This page is an archive of entries from November 2014 listed from newest to oldest.
October 2014 is the previous archive.
December 2014 is the next archive.
