(1) What is a clean room
A clean room is a room supplied with particle removed air filtered by high performance filters (HEPA filter, ULPA filter). The room air pressure is kept high (positive) to prevent infiltration of airborne particle contaminants.
(2) Types of clean rooms
There are following 3 types of clean rooms classified by air flow types (see [Fig.1])
![[Fig.1 - a] Unidirectional flow clean room type [Fig.1 - a] Unidirectional flow clean room type](http://www.misumi-techcentral.com/tt/en/lca/images/115_01.gif)
(3) About cleanliness localization
Cleanliness localization is a concept of keeping only the required localized space clean where especially high levels of contamination control within a clean room. Following two types are the main elements of cleanliness localization, and represent a concept of realizing clean environments where necessary as opposed to making the entire room clean.
(4) Standard clean room example
[Fig.2] shows an example of a standard clean room. Clean rooms are design to administer proper contamination control for the work to be performed. The cleanliness is made to get higher from the entrance on. The layout is designed according to the types of work (work area, equipment area, maintenance area, passage way, preparation room, etc.).
![[Fig. 2] Standard clean room layout [Fig. 2] Standard clean room layout](http://www.misumi-techcentral.com/tt/en/lca/images/115_02.gif)
![[Fig.1] Figure of two parts fastened with a bolt and a nut [Fig.1] Figure of two parts fastened with a bolt and a nut](http://www.misumi-techcentral.com/tt/en/lca/images/111_01.gif)
![[Fig.2] Loosening model caused by force applied at perpendicular to axis. [Fig.2] Loosening model caused by force applied at perpendicular to axis.](http://www.misumi-techcentral.com/tt/en/lca/images/111_02.gif)
